Pick up
gaz_powell
dont forget to araldite the soldered joints
Architecten
Main scooter: Allwyn Pushpak GP125 (RT200)
yup, all done...
Yanker
Architecten wrote:I finished soldering up my stator last night after replacing the LT coil and pickup. It now reads 511 and 94 respectively. What happens when it goes back on the scooter is anyone's guess...!
94 is on the low side (out of tollerence) on the pick-up: should fire and run though!
Architecten
Yeh I know, but what's 1 ohm between friends! But it is higher than the one I took off, that was 82. The LT coil read 293. No wonder i couldn't ride it home from St Bees!!!
I wouldn't worry about the pickup, it's on a par with most Indian coils I've tested, Italian ones read higher and the BGM ones are about 115 ohms
