12v bgm stator, what loom.
idc23
Main scooter: lambrettatv175 3
I have fitted a 12v bgm stator, bgm reg, i have used the original 6v loom, the lights are so dim , brake light ok, but side & headlamp are crap, do i need to change to 12v loom, this is a series 3.
Cheers Ian
Wire is wire there no such thing as a 6 or a 12v loom.
You probably need to check your existing loom for continuity / resistance , 50 year old copper wire can corrode inside the sheathing. Check the resistance on each wire with a multimeter. It should be 0 or close to. Any more and it's suspect.
Also check your earths.
How is the magnetism of your flywheel / what type is it?
idc23
New sr lightened f/wheel. :?
Ok if stator and flywheel are new then look to the loom and earths for high resistance values.
idc23
Ok thanks for your help. ;)
It always amazes me that with the myriad of electrical issues people face the last thing they will replace is the loom and yet it's the cheapest item in the link. BGM loom is less than £20.
http://www.lambrettaspares.com/spares/b ... m0318.html
    Users browsing this forum: Ahrefs [Bot] and 7 guests
