I thought the clutch was very heavy, but the MOT tester (who has lots of experience of Lambrettas) reckons it's abnormally heavy too.
I have:
5 x 3.5mm surflex friction plates
4 x 1.0mm steels
2.0mm top steel
TV200 springs (slightly stiffer, but I have no idea what stiffer means in numbers)
I was thinking about replacing all the friction plates with 2.5mm BGM ones and replacing all the steels with 1.5mm ones. That way, I'll reduce the spring compression by 3.0mm. Is this too much? if it is, I could fit a 3.0mm top steel thereby reducing it by only 2.0mm.
Advice please?
By the way it's a GT186 with sito ancillotti, 25mm phbl through airbox, so it probably doesn't need anything more that a standard clutch anyway.
Here's a picture just because I think it's sexy
