Mikuni issues with 1st 1/4 throttle
sharkman
Hi looking for help with the above. Running a TS1 230 and in 1st quarter throttle if splutters quite badly but then clears and takes off like a scolded cat making it very hard to ride in town. I was told it is because the atomiser is worn but can't be changed as it is part of the carb body unlike a dellorto.
Has anyone else had this issue as I would hate to replace it and find no difference.
Cheers
sharkman wrote:Hi looking for help with the above. Running a TS1 230 and in 1st quarter throttle if splutters quite badly but then clears and takes off like a scolded cat making it very hard to ride in town. I was told it is because the atomiser is worn but can't be changed as it is part of the carb body unlike a dellorto.
Cheers
What are your existing settings?
Main Jet - Pilot - Needle - Clip?
wax
Best put that glass of red wine down / reefer (delete as applicable) and get your spanners out Sharkey [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
Mr G in NYC
Main scooter: SX200
Main jet too big ? whats your set up carb wise ?
