Avanti Jetting
mick1
Main scooter: Li Avanti 225
monkey boy wrote:23 to around 16.
On setting C you would retard to 10.8 @ 8000 revs
I reckon you may be running with too much retard. try a different setting. I use number 7.
Here's a link to for the M Tech settings (courtesy of the MB site) http://www.lambrettaspares.com/pages/do ... ctions.pdf
monkey boy
I see what your saying,
Thing is,it's at low revs it's,s**t.So surely that's going to be fairly advanced.??
mick1
Have you strobed your timing ?
Might be worth checking then have a play around with the settings.
I do tend agree that the flatsides help to clean up the bottom end......I fitted a Mikuni TMX 35 and was very pleased with the difference it made.
monkey boy
Yes I strobed up the timing,bgm stator and due to the slots the max advance I could get was 23.
On setting b revving all buggery out of it,the most retard I could see was 16 degrees.
monkey boy
What inlet did you use on the Mikuni?
mick1
I used the larger AF manifold (bigger than the PHBH ones), used for the Dellorto 34mm and some Amals (I think ?)
    Users browsing this forum: Baidu [Spider], Google [Bot] and 28 guests
