Eden Port Timing Calculator
Snails
Hi
With the 'Piston Crown to Top of Barrel at TDC' measurement if the piston crown is below the top of the barrel by say 1mm do you enter a figure of 1 or -1?
If you read it out it makes sense - crown to top of barrel - in that order.
So if the piston is below the top face of the barrel it's positive.
If it's out the top it's negative.
Snails
Thanks - just needed to make sure I had it right. :)
