Is it possible to tap a Lammy kickstart a centimetre away to stop it rubbing on an expansion by putting it in a vice and gently using a rubber mallet, or is it always necessary to apply heat to reshape it in all circumstances?
cheers.
Reshaping a kickstart
Tractorman
- Main scooter: Lambretta li150 special
It is better to put force on the lever with a piece of tube or stilsons rather than hitting, more controlled. Problem with heat it spoils the chrome but it is better.
Be careful using heat , I managed to soften mine , but I think the problem was I was using a blow lamp so the heat gradually built up , you might be ok if you was to use oxy acetylene because of how quick it would heat the metal up
- coaster
That sounds familiar from O level metalworkDigDug wrote:It's how quick it cools that affects the property of ferrous metals and alloys.
I have reshaped one of mine using one of those yellow bottle blow torches (B&Q). Heated it to cherry red and used a lump hammer to do the 'adjustment'. I did that a year ago and it has been fine but it did affect the chrome. Not a problem in my case as needed to paint it matt black anyway. You won't get anywhere using a rubber mallet
Sorry for hijacking this thread , would it possible then to re harden my kickstart then , I pursume heating it up and quickly cooling it , it's a original sx200 one !
B-Race Tuning
- Main scooter: Lambro, GP.
dom, technically yes, no problem. Regarding reshaping kickstarts, Ian at Taffspeed is a dab hand. It was a regular job on the dodgem
onthelam
- Main scooter: not yet
If you want a gentle bend? Maybe a conduit bender? If you have a mate that has one?Tractorman wrote:It is better to put force on the lever with a piece of tube or stilsons rather than hitting, more controlled. Problem with heat it spoils the chrome but it is better.
Tractorman
He might not be your mate long if you try to bent solid bar with a tool designed to bend tube.onthelam wrote:If you want a gentle bend? Maybe a conduit bender? If you have a mate that has one?Tractorman wrote:It is better to put force on the lever with a piece of tube or stilsons rather than hitting, more controlled. Problem with heat it spoils the chrome but it is better.
