Petrol resistant silicone sealer
Livi- Graeme
- registered user
- Main scooter: Lambretta li 185 series 2
- Contact:
I need to seal a aero type filler to a long range tank anyone know of a petrol resistant sealer I could use thanks Graeme
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
There is always some confusion between builders/plumbers silicone sealer and automotive silicone sealant. You need to get some of the latter I use Loctite 5910 and there are others equally as good, threebond for example.
- sunrisemac
- registered user
- Main scooter: Lambretta GP150
- Contact:
Blue Hylomar is fuel resistant
There are very few truly fuel resistant sealants, done my time in a shop enviro, flushing blue slime out of carb jets. We use Loctite 5922 paste on fuel senders, which is rated fuel resistant & pretty much an industry standard bodge.
If you'd rather do the job proper like, buy a sheet of 1.5mm nitrile bonded cork, nick your missus nail scissors & cut yourself a simple gasket that's guaranteed to seal & not dissolve into your fuel. Alternatively you can also use 1.5mm Viton rubber sheet. Do it right, do it once
Tractorman
- registered user
- Contact:
Hylomar is excellent to smear on gaskets or replace them on precision joints but not sealing a fuel tanks or not so good joints.sunrisemac wrote:Blue Hylomar is fuel resistant
In a past life I worked for a company that made re-fueling riggs for the F1 industry. We found NO silicone that was truly petrol resistant, in a sheet form or liquid. It would always breakdown, go soft and fail. We would also use good old cork or nitrile sheet, and where possible we would joint with nitrile O rings.
- sunrisemac
- registered user
- Contact:
really? i've never had a problemTractorman wrote:Hylomar is excellent to smear on gaskets or replace them on precision joints but not sealing a fuel tanks or not so good joints.sunrisemac wrote:Blue Hylomar is fuel resistant
