My DL200 Electronic project
Villmark
Main scooter: DL200
Toddy wrote:the casings have come up nice, excuse my ignorance is blasting with walnut shells as it sounds ?
Not an expert on blasting but according to Jockeys Boxenstop who did the job blasting with walnut powder is less abrassive than bead or sandblasting but hardens the surface of the casings and is better to clean. The casings are smooth, not much difference from original condition but clean and without alloy corrosion.
Villmark
Main scooter: DL200
NOS Chainguide
Gori DL200 kit
Original cylinder head
TS1-200
Please, don`t get me wrong this is not a criticism, I think your project is good and I am very envious like a lot of others reading this thread I expect, just like to clear up a doubt in my mind, your rear light assy. is that a remade one as I thought the originals would not have had cross head screws, only saying that as I bought one the same for my GP, couldn`t make my mind up about it. they are very good though.Look forward to seeing it finished.
Keep on keepin on
Villmark
Main scooter: DL200
Thanks for your post TS1-200. The cross head screws on the rear lens are correct. The screws are repros from Scootopia.
But my headlight is not correct. Anyone has a genuine DL GP headlight unit for sale ?? or TRADE ??
Chris Tindal
Main scooter: GP150
Your headlight could be correct. Apparently there was two types of 'original', those with the dots between C.E.V. and those without dots but with the little planet and different 'innocenti' font. Yours looks the type without the planet but I wouldn't rush to change it
Budenzauber
Please put off the bottom chain guide...
Villmark
Main scooter: DL200
Budenzauber wrote:Please put off the bottom chain guide...
Why ??
georgelemons
TurboTrev wrote:
Villmark wrote: I cleaned up the original rear shock as the new ones available from CASA are not painted on the top and the ones from TUTTO (look great) are SX-Type rear shocks.
After cleaning I coated the shock wit Owatrol to conserve. Quite happy with the result (compare with pics before dismantling).
Parts are coming together nicely, looking forward to seeing more. Just out of curiosity, what is the difference between an original GP/DL rear shock and an SX shock?
Trev...This is a LIMS shock, not a SCM. Innocenti used on late GP/DL's production. Good to see its been used again :) The front shocks should be LIMS aswell.
Front shocks should have stamped - number 2, Patente(below it), LIMS oval logo, ITALY(capitals) and then 509 (think thats correct, from memory)
TurboTrev
Thanks Preston, it seems like yonks since I've seen a post from you! Are you still on the lcgb board? Cheers. Trev. (edit - saw your old yellow GP200 in the flesh the other day, looked beautiful!)
georgelemons
Nope...left ages ago, Trev. YES...my old GP 200 looks great!! :) Glad I sold it to Tim...went to the right person.
