What are the pros and cons of cast iron vs. aluminium barrel
grimspeed
Main scooter: gp 283 kx
I'm going iron on my T5! Polini cylinder + Polaris 650 piston + P2 crank with a long Mito lambretta blade rod 115mm .
I also love the cheep Indian cast lined cylinders for playing with and they make great touring kits with jap pistons !
If they nip up a bit of emery cloth can normaly get you home. Both my Ts1's are lined and im now looking for a RB
that's knackerd to have iron lined !
Monty
grimspeed wrote:I'm going iron on my T5! Polini cylinder + Polaris 650 piston + P2 crank with a long Mito lambretta blade rod 115mm .
Some one we may know....
http://www.ebay.co.uk/itm/Lambretta-RB2 ... 43da20ac69
eden
is that ware around the exhaust port? if it is, iron don't ware like that :lol:
Grumpy225
eden wrote:is that ware around the exhaust port? of it is, iron don't ware like that :lol:
That looks like a ring snapped and took out some aluminium along with the plating :shock:
Muppet
mabee peg fell out ring spun round
C’est la vie
soosh
I've never had an issue with running in an iron barrel and certainly don't do 100mls. It's how you run them in,not how long.
eden
soosh wrote:I've never had an issue with running in an iron barrel and certainly don't do 100mls. It's how you run them in,not how long.
very true. :D
Rich_T
Main scooter: Li Special
Muppet wrote:mabee peg fell out ring spun round
Yes, It looks like that to me.
Someone mentioned earlier about far east scooter having iron barrels and how could this be if it is cheaper to make a plated alloy barrel. The answer to this question has several angles. 1. Labour costs are hugely lower 2.floor space is not at a premium 3. The designs are all small enough and simple enough to run on continuous Disamatic foundry lines (these are the sort of lines that make plumbing parts) 4. the foundry is specialised in producing similar iron parts on automated lines (like air compressors etc). 5. They will not be paying energy prices anywhere close to European bills.
These 5 factors are massively different to what we have in European production and make all the difference. The biggest influencers are design complexity, energy and labour costs. If you have a simple, small design and you build it on automated mass production where the labour and power rates are the cheapest it will be a different story. Unfortunately that is not possible to do with a performance barrel.
Yanker
eden wrote:is that ware around the exhaust port? if it is, iron don't ware like that :lol:
Hum? Your ASSO or whatever piston drops a peg: it chumps it JUST LIKE THAT.
eden
nope, it just fucks the top and maybe the bottom of the port, the damage would be nowhere near as bad as in that pic and could be ground back out in 10 minutes.
    Users browsing this forum: No registered users and 31 guests
