O-tuning V5A for my elder son (hot french recipe inside)
jackson85
Main scooter: T5mk1
Nice work fogger. Hope the young lad appreciates what his old man is doing for him. Looking good. Glad to see you back working on vespa
fastfrog
My soon enjoys the whole project but fears a bit the gear change thing. I guess I felt the same when I was fourteen/fifteen.
I should have the casings back from the welding shop next Tuesday.
Size matters!
tony172
Main scooter: vespa t5
can i ask how you dug those boost ports out?
fastfrog
with my teeth!
....and a mobility flexxi. great and easy to use as a grinding tool. Far better than any pneumatics or loosy dremels... speed controlled by pedal, lots of torque instantly poured even at very low revs... A dream for any old fashioned tuner...
Size matters!
jackson85
Main scooter: T5mk1
Ah he will love the gears frogger. Riding an auto is for lazy people
fastfrog
Sure, or I'm good for a paternity test!
Size matters!
fastfrog
welding job and 2,5 mm packer done:
transfer prints are just for show. They will be a bit smaller....
Size matters!
nice work ,will you be keeping the std (16/10)carb or using the better 19mm one as used on bigger 90/100/125 vespas ?
fastfrog
I guess 16/16 is a perfect match....
Size matters!
fastfrog
Looking for a decent head, I must admit the original one is a crap without no Squish band at all and a lousy cup shape. Polini does one a bit better for its 50cc kit. It is oddly too large with 41,8 mm for a 38,6 bore. I can imagine the pinging noise from my seat. Anyway I can schrink it to 40mm by skimming it.
Need to check if squish ok with a meteor piston.
Size matters!
    Users browsing this forum: No registered users and 20 guests
