This is probably going to sound like a very stupid question but you only know what you know.
I have recently bought a 1962 series 3. It has a 12V upgrade. I am interested to know about the key. I have never had a Lambretta before but have had dozens of "modern" bikes from sports to tourers. I put the key into the barrel below the headstock (left hand side), turn anticlockwise, and kick start. No problem. I can also use the same key to apply the steering lock by turning the barrel clockwise.
All good up to this point. However, I had started the scooter the other day and whilst giving it a rub over with a cloth I pulled the key out. I was amazed that it would come out quite so easy but even more surprised that the scooter kept running. How does this system work. Just for info it has a cut off switch below the speedo to kill the engine.
Like I said probably sounds a bit stupid to the more experienced Lammy rider but I can't find any info on the net specific to this.
Cheers for any help.
Key issue
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
I had a Casa switch were the steering lock key would go in and work the ignition switch but would fall out in the run position. I figure the key were near enough to fit but loose enough to drop out.
Chris in Margate
- registered user
- Main scooter: Lambretta 1964 225 Special
- Contact:
Not standard but fitted later. Fully anti- clockwise is OFF. 1 click clockwise ON; another click is ON + "sidelight"; and another click is ON + headlights.....normally !
On worn locks the key can come out without affecting the engine or lighting.
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
It sounds like you are mistaking the steering lock for an ignition switch,if your scooter is fitted with a kill switch button it wont have a key operated ignition switch.
Blenks
- registered user
- Main scooter: Lambretta S3 Li150
- Contact:
So if I am not mistaken, if what you are saying is correct (just a steering lock) that would mean that it will kick start without a key??????? Surely this would mean anybody could ride away with my newly acquired Lammy free and gratis. Now I know technology has moved in in the past 50+ years but come on????? Is the only security then the steering lock and no ignition key.
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
join the wonderful world of Lambretta!!
TBH the more upmarket models did have steering locks AND ignition keys which were a waste of time. Suggest you invest in a very strong "Oxford" type chain and lock and lock it to a lamp post whenever you leave it- otherwise they will simply lift the bike into a transit and off they go.
Chris
Chris
Scootering since 1968.
Yup ! ............Blenks wrote:So if I am not mistaken, if what you are saying is correct (just a steering lock) that would mean that it will kick start without a key??????? Surely this would mean anybody could ride away with my newly acquired Lammy free and gratis. Now I know technology has moved in in the past 50+ years but come on????? Is the only security then the steering lock and no ignition key.
Blenks
- registered user
- Contact:
WOW!!!! frightening really. Still it is what it is. Thanks for all the responses and for not taking the P. If it was not chained to something solid as Chris says they would not have to lift it into a van they could just kick the bars to snap the steering lock (which I guess is like most bikes and made of cheese) and ride it away. They wouldn't even have to use there own petrol
- registered user
- Contact:
you don't need to kick the bars to snap the steering lock, a reasonably determined toddler could probably do it in 2 mins...
