110 Yam Rod on a SIL 200
Lamaddict
I'm just going to build my top end. I've Yamaha 110 conrod in a standard SIL barrel with a standard size SR piston, I have the 3mm packing plate but the head is not skimmed so to get the squish I may have to put the packing plate on with gasket seal......
Has anyone tried this set up on a SIL barrel? Any tips?
johnd
Main scooter: 1970 Dl125
Lamaddict wrote:I'm just going to build my top end. I've Yamaha 110 conrod in a standard SIL barrel with a standard size SR piston, I have the 3mm packing plate but the head is not skimmed so to get the squish I may have to put the packing plate on with gasket seal......
I use a packer on my RB with just loctite gasket sealer, no leaks so far.
Diablo
When I use packers with no gaskets I use 1104 gasket sealer. Very good for gasketless joins.
http://cgi.ebay.co.uk/3-BOND-THREE-BOND ... 240%3A1318
For heads this stuff is the best I've ever used and I swear by it now. Its been stopping brit bikes leaking for years!
http://cgi.ebay.co.uk/Stag-Wellseal-Joi ... 240%3A1318
johnd
cheers for that wellseal link i've been searching for that for ages!
Lamaddict
Thanks very much for the feedback.
Which would you compromise the better squish or the lower port timings?
Lamaddict
Anyone on my later comment? :)
    Users browsing this forum: Google [Bot], Semrush [Bot] and 10 guests
