I have noticed there are quite a lot of series 3's out there that have a rear that's going to the left but far more seem spot on. I did try and remedy it by putting an offset cone in the left side only and rotating it till the wheel was plumb but it crabbed something awful so I binned that idea...
Anyways I'm guessing that the scoot has had a whack at some point in its history and this has probably pushed the loop to the right a tad.
so how easy would it be to split the two sets of welds that hold the loop to the frame at the rear, then move the loop across 5-10mm and re-weld? Obviously this would mean losing the paint on the loop but I'm not bothered about that. I think I would need to get some sort of jig to hold the frame so I know I'm moving the loop not the frame....
Any suggestions welcome
Sef
