fitting a fuel pump to stock fitting carb
soulboy
Do they have reserve i thought it was just on and off
hobospeed
Yup
http://www.sip-scootershop.com/en/produ ... r_15878000
Fuel Tap SIP Fast Flow for
Vespa 50-125/PV/ET3/PK/S V30
-33/VM/VN/VNA-TS/150 VL/VB
/VBA-T4/GS VS1-5/160 GS/180
SS/Rally/PX/T5
with lever (length 200mm),
with reserve
soulboy
So were is reserve then
soulboy
Thanks for all this help by the way new u wernt a british scooterist with all the help im gettin
hendy
soulboy wrote:Thanks for all this help by the way new u wernt a british scooterist with all the help im gettin
How to make friends and influence people
soulboy
Ha ha i was havin a bit of a joke a out british scooterists there is a lot of clever geezas on here i thought i new the ins and outs of a vespa but this is pissin me right off just that one problem then the scoot is perfect
soulboy wrote:Its already got a sip fast tap mate
I think that's why he said fit the BGM one ;)
lambro
Have you deffo got a Dellorto float needle in there?
Some Indian ones (Jetex for example) are longer and restrict fuel flow?
I put a fuel pump on my SS90 rep with a 32mm and all it did was cause me problems.
Agree about needing them with large carbs on Lardies with 210s etc,
But a ported 172 will be fine with a fast flow.
I reckon fuel pipes too long/kinked.
Knowledge
Did I read somewhere about using the T5 carb, as it had a bigger float bowl, and then some clever person started to produce a little extension to the standard P200 carb.
Perhaps I imagined it. Vespas really aren't my thing, man.
Martin
goldeneye
im about to fit one of these SI carb float bowl extensions to a malossi 166 ive just built, which is suffering from fuel starvation at higher revs, gonna do the carb mods re- drilling the passage from the float bowl to the jet stack , and cosa float bowl as well, I"ll put the results on if I remember.
