Crankcase damage
DickieD
Main scooter: 1970 GP 200
Just stripped the brother-in-laws motor after he broke down. thought that he had dropped a ring peg or something like that. On stripping found that his small end bearing had failed damaging barrel and crankcase. the barrel is going of to Langcourts but my question is will the damage to the crankcase need repairing or can it be lightly filed and wet and dry. Any advice would be great see photos below.
Cheers Paul
20150314_161658
20150314_161618
DickieD
That didn't work i'll try and upload images again :lol:
Image20150314_161658 by pauldavies360, on Flickr
Image20150314_161618 by pauldavies360, on Flickr
Den 08
Main scooter: lambretta Gp 225
I would not fill that, a bit of wet /dry check for hairline crack, its a bit thin their, should be good to go,
Den
^... agree. Check to make sure that there are no cracks going through to other side. If not, simply dress it and use as is.
warts
Main scooter: honda
Filed yes, filled no.
Have youused langcourts before as ive not heard good things about them I guesss there cheaper than poetons
TS1-200
Agree with Shocky.although I`m not too sure about what I`ve heard about Langcourts I`ve used them with no problem, but I had my last barrel done by Aptec, a little bit more expensive but I think better.
Keep on keepin on
lambro
shocky wrote:Have youused langcourts before as ive not heard good things about them I guesss there cheaper than poetons
I use Langcourts all the time. never had a problem.
Dave down there is a legend, and top bloke for advice and help.
Shaun.
I also have a Malossi going in tomorrow for plate, they also do all my cast barrels for boring.
DickieD
Many thanks for the advice much appreciated. I have used Langcourts a few times and have never had a problem with them. I will stick some pictures of the barrel and comment on quality of work when it comes back, £150 for repair and replate I don't know how that compares with others?
    Users browsing this forum: Google [Bot], Semrush [Bot] and 20 guests
