pulling my hair out ..t5
soulboy
been having a few problems with it ..now ive put a new 26mm carb on and still av the problem it runs fine then just stops as if the ignition as been turned off or the petrol as been turned off please please help don't no weather its electrical or fuel :cry:
Norrie Bodge
IMO sounds electrical
process of elimination...
1. new plug
2. HT-lead
3. CDI-Unit ( borrow one of a mates working bike )
4: Pick-up on stator
mick1
Main scooter: Li Avanti 225
My guess fuel.......Sounds like the bowl is emptying and not filling fast enough. With it being 26mm have you put a fast flow tap on?
tony172
Main scooter: vespa t5
i had this on my t5, was the pick up on the stator plate. swapped that and solved the problem. hope its that easy for you
soulboy
cheers tony
soulboy
mick1 wrote:My guess fuel.......Sounds like the bowl is emptying and not filling fast enough. With it being 26mm have you put a fast flow tap on?
yes mick ive got a fast flow on it
have you checked out the readings from the stator ?
gavi4t
Main scooter: lambretta gp450
check your fuel pipe is the right length if its too long this will happen
lockman69
^^^^ what he said, did you change the fuel pipe?
soulboy
piston in wrong way :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :roll: :roll: :roll: :roll:
