200 cylinder to small block conversion?
Chris Tindal
Main scooter: GP150
Hello
Does anyone know of a dealer/engineer in the West Yorkshire area that will convert a GP200 cylinder and head for a small block casing? Oiltech only convert casings. If anyone fancies the job or knows anyone please let me know.
hungdog
cgt75b
Main scooter: lambretta
I think you are talking about turning down the spigot, and opening up one of the stud holes ?
DigDug
It would probably cost you as much as sorting a small block to suit the cylinder.
Did you have to do that?
Grumpy225
That sounds like the hard way to do it.
Why not just long stroke a 65mm bore?
a 60mm stroke crank will give you 199cc on a 65mm bore with no case or cylinder mods.
Chris Tindal
Main scooter: GP150
hungdog wrote:?
Turning down the spiggot and drilling the stud holes to 13/14 mm allows the 200 cylinder to be fitted onto a small block casing. It's straightforward, if anyone knows who can do it let me know.
Chris Tindal
Main scooter: GP150
Grumpy225 wrote:That sounds like the hard way to do it.
The bottom end is already built with the original 1970 crank.
ktmh5
Main scooter: GP225 Mugello
Tried Chiselspeed?
Chris Tindal
Main scooter: GP150
I'll give Chiselspeed a call Monday, cheers.
Chris Tindal
Main scooter: GP150
Had a reply from Chiselspeed, they will convert 200 cylinders to small block.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
