DC electrical System?
rog60
Main scooter: Indian GP200
As I am a numpty with electrical theory, can any tell me if it possible to change the 12v AC from the regulator to DC using a separate rectifier and then use the DC voltage to power all the lighting on a Lambretta?
soullad
Rog - PM Soulsurfer (Mike) on here - he has the ideal conversion for you. In fact come on Mike show the world your DC system................
CANbus
soullad wrote:Rog - PM Soulsurfer (Mike) on here - he has the ideal conversion for you. In fact come on Mike show the world your DC system................
hello Mike aka Soulsurfer, have you looked at your rectified dc voltage with a multimeter? how stable was it? thanks.
11111111 = 0xFF
It's stable at 14.5 volts just about anywhere in the sytem and at different rpm, I was impressed with how stable it was and at £24 delivered for the reg/rec, I think it's a no-brainer ;)
oioivespaboy
Hi there, long time lurker, first time poster.
I live exactly half a world away from most of you lot with all of your shops and know how so this board has been a wealth of info for me, thanks.
Little bit off topic but I have been reading about people converting their electrics to full wave DC
and the following schematic has got me wondering.
It seems that people are isolating the AC side from earth and then earthing one leg of the DC. Wouldn't it be easier to leave the AC leg earthed and then isolate the DC leg from earth? It would require extra wires to be run to lights, horn etc, but it would save messing around with the flywheel.
Possible???
I dunno but it seems easier to modify the stator to me :? It's not difficult, just mark your stator position, undo, desolder the earth, run the new wire and you're done. If you ever get stuck and need to fit a Vespa type regulator again, you can just earth the extra stator wire to the frame and you're back to AC. Simples :D
firekdp
oioivespaboy wrote:It seems that people are isolating the AC side from earth and then earthing one leg of the DC. Wouldn't it be easier to leave the AC leg earthed and then isolate the DC leg from earth? It would require extra wires to be run to lights, horn etc, but it would save messing around with the flywheel.
Possible???Cheers
Yes it would be possible, but along with wiring everything back to the battery negative you would have to fit another horn switch somewhere, so one wire at the stator is far simpler.
rog60
Thanks,nice easy to follow but for an idiot like me when you say earth connection broken and new wire added, I assume that means connect old earth wire to new (yellow) wire as ' new'circuit?
Also I have modified Indian loom with front brake light switch similar to the MB one in Sticky's manual but the ignition wires (green, white and yellow disappear into the loom and reappear at the CDI. I presume the ignition circuit is totally separate from all this?
rog60 wrote:Thanks,nice easy to follow but for an idiot like me when you say earth connection broken and new wire added, I assume that means connect old earth wire to new (yellow) wire as ' new'circuit?
Yes, I would run as,say yellow/green, just so you know which one it is :idea:
rog60 wrote:Also I have modified Indian loom with front brake light switch similar to the MB one in Sticky's manual but the ignition wires (green, white and yellow disappear into the loom and reappear at the CDI. I presume the ignition circuit is totally separate from all this?
Correct. You only connect black to frame earth and red to the loom, the two yellows connect to the stator wires (yellow and yellow/green), it doesn't matter which way round the stator wires go.
Hope this helps
