fuel tap with long mounts
crooky
- Main scooter: 1960 series 2 li stg 4 175
Just upgraded series two years to long mounts and now my fuel tap fowls the mount as in its too long to get back in. Am I missing something or do I just need a shorter fast flow tap. Thanks for any advice
The man who doesn't read has no advantage over the man who can't read
Yerst, it's a bit of a buggerthat. I've had it happen a couple of times. HXPaul gives one answer. The easiest answer is to buy a rear exit FF tap.
crooky
So will buying a scooter restorations fuel tap give me the same problem? I was hoping mine was a long one its a cam lam fast flow if that makes any difference thanks for the replies and will a rear exit one go straight in without issue. If I sound desperate I am going Morecambe at weekend thanks again for the advice.
- HxPaul
- Main scooter: lambretta Li 150
It just depends,if its the exit spout thats fouling the mounts,that may work,but if its the body of the fuel tap thats fouling then it wont make any difference getting a rear exit tap.Daggs wrote:Get this, your troubles will be over.
http://www.lambretta.co.uk/shop/fuel-fa ... -3179.html
Tractorman
- Main scooter: Lambretta li150 special
Slacken off the tank straps and put some rubber strips between the tank and tank rubbers to lift the tank.
