exol oil - gumming up rings and big end lubrication - update
gaz_powell
Its been a while but I thought this was a useful update for those interested
There were some related topics on here last year regarding gummed up rings, a possible lack of lubrication to gudgeon pin and exol oil - started around a vespa p range 200 motor.
I was involved as I had the same issues on the same vespa motor as the original author.
As a comparison I said I was going to strip my lambretta top end to replace a few parts and have finally done it yesterday. Having ran the lambretta at 3% on exol ss for more miles than the vespa .
Stripped my TS1 SX top end to replace piston (if required) but definitely change rings and reeds - piston was good, rings were free, gudgeon pin and small end bearing had no signs of wear as found on both vespas. Only real issue was a knackered engine mount !
For the record the bike was rebuild with new reeds, rings, base and head gasket, small end bearing - then a chain adjustment check/inspection was done, fresh oil, new plug etc - and some new mounts.
this makes me believe that the vespa problems in my case - gumming up around the rings was due to excessive bore/piston/ring wear and the gudgeon pin was a crap pin.
this season I will be sticking to exol ss on my vespa, 2x nicosil TS1s and 1x steel lined TS1
mick1
Main scooter: Li Avanti 225
Good to hear as I've just bought 20L (£4 a L delivered) of the fully synthetic. I've used the Exol for the last couple of years on my Avanti (2%ish) and had no problems.
ArmandTanzarian
It was my PX motor that had the problems. The gudgeon pin was probably faulty case hardening. The rings gumming up, who knows. I used the same oil (different scooter) on a trip to Italy and back without any problems.
gaz_powell
i was always happy with the performance of the oil as my bikes (both lam and vep) are used under hard riding with no ill effects and I did not consider my vespa problems were associated with it.
people were quick to jump to blaming the oil
ArmandTanzarian
gaz_powell wrote:i was always happy with the performance of the oil as my bikes (both lam and vep) are used under hard riding with no ill effects and I did not consider my vespa problems were associated with it.
That could be the point. When mine gummed up it had spent the last 7 days on a gentle 1200 mile, 50mph pootle around the minor roads of Britain and Ireland
