Black series 3 trim?
Ian Hepworth
sydduckett wrote:Looking for somewhere that sells black series 3 floorboard and rubber kits. I think series 3,s only came with Grey as standard, hence the difficulty in finding them. Have used black GP kits for the rubbers and floorboards but have problems with both, horncase rubbers to short & wrong fitings cos of the sharks teeth... :evil:
Ta
sef
For horncast side rubbers try scootopia, they get it on a roll so could sell you something a bit longer.
scootRS.com wrote:>>the heads of the screws you use are round and in some cases could not be tightened up. This is a flaw that you need to look at
Already fixed.
Stock was all melted down and redone many months back, as soon as I found out the specified bolt heads weren't used. (They were round with a nut and it would push up if over-torqued.) Only found out after a bit; normally it didn't happen.
If you need a replacement for yours, send an email in with the info and we'd be happy to change it.
That's very kind of you Randall, but I have mixed and matched now. Still, I'm glad to see that you are on the case.
scootRS.com
Ian Hepworth wrote:can you make the two small LI ones (the ones that go on the legshields rather than the rear runners) but in black. That would sort the original posters problem out runner wise.
We do make them but we make/sell complete sets.
Ian Hepworth
Ok, makes sense.
Series 1/2 on the way in grey and black?
scootRS.com
Just finishing up the floor rubber, horncast rubber and other bits now.
We are working on the S2 ones, not sure how long it will be offhand. The Italian S2 ones are appallingly bad quality. I did ask here if anyone had an original we could buy or even a really good photo of an original but no response. Still interested if anyone has one.
Ian Hepworth
scootRS.com wrote:Just finishing up the floor rubber, horncast rubber and other bits now.
Got a feeling I kept the ones off my series 1 but they were in really bad condition. I can look for them next time I get into the garage.
