Edit: OK, guessing that 64.5 bore gives something like 185 (guessing!) and the figure of 29cc being more 'in the ballpark' (32 and 34 were getting very large for a small block!) then this would give something like 7.4:1 geo... certainly not high compression for a standardish barrel on today's fuels. I'm way beyond looking into corrected at this time of night but a high exhaust port would cause this fairly low geometric to become a very low corrected. However, don't start to think that the corrected numbers should be anything like the same range as geometric... a well respected UK tuner and successful racer once quoted me corrected target figures of 6.25:1 for road/tour and 7.5:1 for road/race. Just as your geometric looks low'ish so does the corrected figure that you've calculated.Adam_Winstone wrote:Those head volumes for a small cc kit seem very large!? Are you sure? How are you measuring them?
Don't worry about corrected compression for now, I'm trying to get my head around the geometric first.
