Project Rally 180... WTF do I do now!?...
goldeneye
my suggestion. buy a gas mig set. get some old panels to practice on , and do this Rally 180 as a labour of love. there arnt many about, so take your time , and do it a bit of a time. itll be great in the end.
cartmel808
goldeneye wrote:my suggestion. buy a gas mig set. get some old panels to practice on , and do this Rally 180 as a labour of love. there arnt many about, so take your time , and do it a bit of a time. itll be great in the end.
I ain't no welder Goldeneye... set me loose on that with gas mig set & all I'll end up is a s**t load more holes ;)
Me mate said it would make a good sprinter project coz it's a light as f@@k :lol:
cartmel808
Muttley McLadd wrote:Have you got any pre blasting photos?
Here's how it looked before I stripped it - but got no pics of it stripped pre-blasting...
goldeneye
wow, looked alright actually! shows what you buy eh! (luckily my three are all sound as ive built /chosen the bits myself) I"d still give it a go, 180"s are getting rare, it might be a pain in the arse , but I would do it if I were you.
Didn't look too bad, maybe just as well you striped it ..
cartmel808
The biggest problem area is the rear 'engine side' quarter - the lower third, of which - from rear of frame tunnel right round to the tale is proper crispy & will all need cutting out & replacing - I've seen the tale section half's for smallies, & something like that would be ideal - but not seen the same anywhere for largeframes?
The battery side rear quarter has some small issues, but only in isolated areas & nowt that would worry a decent metal worker.
Frame tunnel looks to be very solid though & the leg shields are surprisingly very straight.
I've got to say though - whoever it was that sculpted & grafted all that bodge & filler onto it back in the day did a commendable job. lol
goldeneye
get in touch with pete gavi (GAVI 4T on here) he"ll sort that for ya. great painter as well.
ArmandTanzarian
cartmel808 wrote:The biggest problem area is the rear 'engine side' quarter - the lower third, of which - from rear of frame tunnel right round to the tale is proper crispy & will all need cutting out & replacing - I've seen the tale section half's for smallies, & something like that would be ideal - but not seen the same anywhere for largeframes?
I've seen repair patches, maybe they can be adjusted to fit a Rally. Even if not, its all fixable if you find the right person for the job
http://www.ebay.co.uk/itm/VESPA-RALLY-2 ... 1173317129
http://www.sip-scootershop.com/en/produ ... r_pv153481
cartmel808
goldeneye wrote:get in touch with pete gavi (GAVI 4T on here) he"ll sort that for ya. great painter as well.
Is that the lad in Darlo?
weeks
Cant confirm that Peters forum name is what Jeff has written but id confirm Peter Gavi is from Darlo and does some excellent work.
Good luck with the Rally fella
    Users browsing this forum: Amazon [Bot] and 2 guests
