Disc brake woes
phil23fair
Main scooter: Lambretta Li 250 Special
warts wrote:As mentioned by Shocky, it could be the master cylinder is too big, moving too much fluid and the brake therefore too aggressive.
Isn't it the size of the master cylinder piston that needs to be smaller? The ScootRS Nissin master cylinders are marked 1/2. I'm guessing this is for 1/2 inch. The Gilera Runner ones I have found on line are marked 12.7. If that's millimetres it makes the piston the same size as the ScootRS one. I've got 3 scooters fitted with the ScootRS outboard discs and two were great from the off and the third problematic - snatching and juddering until I changed the disc. It didn't appear to be warped on the front face but it was measuring between 4.5 and 5mm in thickness.
sydduckett
As it worked spot on previously, I know it's not the size of the master cylinder but a failure somewhere. I'll strip the calliper as well before I put it all back together. fair point on the dot4, mine has probably been on the shelf, saying that it was used new previously with the same results. May be worth investing in an eazybleed or similar.
tabspeed
Main scooter: Vespa PX200 disc
I had lots of trouble bleeding mine.
In the end up I got a large syringe from the chemist fitted a rubber hose to it and reversed bleed it from the bleed nipple. You will need to bleed it the normal way first to fill the lines, or you will be filling your syringe all the time
sydduckett
tabspeed wrote:I had lots of trouble bleeding mine.
I'm going to invest in a bleeding kit, what do people recommend ?
Ta
TED CRUD
My mate had the same bother with a Scootrs disc brake ,bled it countless times and it was the hose supplied with the kit ,Changed hose and it was sweet
https://www.google.co.uk/url?sa=t&rct=j ... 1416,d.ZGU
Bled another scootrs disc at the weekend no bother with this kit
Smash Ya Pastie
Washington Posse s.c
Speed Demon
I've found that since the change to genuine Nissin components my wife's one became hideously snatchy. I used to manually remove pad area too, which worked but someone told me to try different, less aggressive pads and it worked a treat. You don't need the power of sintered with such a big disc and a small wheel, but organic pads work a treat.
Get to SULK
Argentopercarter
Speed Demon wrote:I've found that since the change to genuine Nissin components my wife's one became hideously snatchy. I used to manually remove pad area too, which worked but someone told me to try different, less aggressive pads and it worked a treat. You don't need the power of sintered with such a big disc and a small wheel, but organic pads work a treat.
Had to read that twice.
sydduckett
You know what when i think back i swapped for sintered pads and thats around when the grabbing issues started. Will look into this.
double h
Main scooter: SIL GP 200
Me to :lol: :lol: :lol: :lol:
double h
No offence meant though, a technical question answered.Just taken out of context to easily amused people like me I found it funny ;)
    Users browsing this forum: No registered users and 62 guests
