GT 186 and 30mm VHSH - advice needed.
GavJ
Main scooter: SX150
Hi all, looking to replace the 28mm PHBH for a 30mm VHSH and was looking for a startpoint on jetting.
Standard 186 kit with ported casings and Devtour pipe.
All help gratefully received.
slangen
Main scooter: TV200
Fron the GT186 fitting instructions:
Dellorto VHSH 30 flat slide with cable choke conversion Part number: 53003
Settings for open mouth with JL3 or KRP3 expansion chamber. Suggested jetting between 125-135 main jet, DP262 (or DQ262) emulsion tube, U2 needle, 55 slide, 35 idle jet, 35 idle emulsion tube (the idle jet and idle emulsion tube are now supplied as one part). Timing set at 17 degrees BTDC.
GavJ
Main scooter: SX150
Many thanks, appreciated!
    Users browsing this forum: No registered users and 22 guests
