lads
does anyone know who does a longer rear damper fixing bolt?
me mate, has a JL-Exhaust fitted & the rear bracket off it fits on with the rear shocker..
there is v-little thread left to fit the nut? nevermind with a washer too?
Longer rear shocker fixing bolt needed
Norrie Bodge
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
ive a JL on mine Norrie, ill have a look to see if ive any bolts the same. get a full width nyloc and washer on mine.(tell him to do the vespa rear suspension bush conversion on it while he"s on, no more snapped JL rear rubbers)
Norrie Bodge
Cheers m8
what does that bush conversion need exactly Jeff
its a bit of stud, a rear shock bush, and a few washers and nuts etc. not a lot really. you going to A19"s at weekend? I"ll take some pics and show ya.
gaz_powell
Gash
Early casings use a 9mm x 65mm long
Late casings use a 10mm x 70mm long
Ebay has plenty of part threaded bolts at M10 x 75 or 80 and beyond for coppers
M9 is the problem !
M9 is the problem !
Norrie Bodge
its tiny tail eggys bike gaz
we just fitted a new rear shocker & brackets must be thicker on it? its on old P2 casings so yep 9mm
Jeff - if you`ve gotta a spare longer 9mm bolt?? tiny-tail says bring it plz with ya picture ov conversion
& will get it off ya on sat night fella
GLscoot
- Main scooter: Vespa GS150
If its M9, then you need to get a GS150 rear shock bolt from Germany. I have tried everywhere in the UK and it seems the Germans are the only ones that have them.
http://www.sip-scootershop.com/en/produ ... k_78724060
Norrie Bodge
cheers m8
i will let me mate know
gaz_powell
I`d change the bush and go to the 10mm - much better if you require a longer bolt - bushes/sleeve are only about six quid
then you can get the exact size bolt easily in the future
