scootrs disc diagram
Minority
Main scooter: Li230 S3
rbgaz wrote:should the two nuts and bolts on the tie bar on the scootsrs antidive be a little bit lose so it can pivot on brakeing ?
The tie bar must be free to pivot at both ends otherwise you will effectively lock the suspension, the tie bar I got with my anti dive kit had a crude type of rose joint to allow this. I wouldn't leave nuts and bolts loose on suspension though   :o
Minority
or you can change it for some proper rose joints as I did.
Minority
dave411 wrote:
TED CRUD wrote:Cheers Lads ,I think i have sussed it . i have searched older posts and noticed the anti-dive bracket needs to be central for a equal performance .too high and stiff too low and it dips under braking
Central to what?
central so you get a 90degree angle like this, or at least that's my theory :lol:
Adyonekenobi
Main scooter: Li150 Special, now TS1 225cc
Nice BGM front dampers, nice powerful disc brake, alloy wheel etc.
So why the crap bracket for the lower damper mounting?
I had them one, both sheard through due to metal fatigue.
I got a great pair of the right trailing links, made by MBD, and they are superb.
Spanner check the running gear before every outing, like in the Army. You know it makes sense!
Minority
Adyonekenobi wrote:Nice BGM front dampers, nice powerful disc brake, alloy wheel etc.
One day, but not high on the priority list at the moment.
Adyonekenobi
Ok
Just keep an eye on those lower brackets for any hairline cracks.
Enjoy your scoot and keep the faith.
Ady
Minority
Adyonekenobi wrote:Ok
Ady
Sure will Ady, hope they don't have the problem you had ;)
