Recomend me a timing light/gun please ?
Rotor
Main scooter: 1960 S2 Italian
Hi can anyone give me a heads up on a timing gun, and if I were to buy one with a tacho is it worth the extra money and will it work on two stoke ok ?
Its my birthday soon so can spend a bit of money ;)
P.
dapper
I use this one as do many others. You may find it cheaper but this is the first one that popped up on e bay. You need a battery to use it. Simple but effective and accurate.
http://www.ebay.co.uk/itm/Draper-52616- ... 2c51550057
Muppet
try t get one with skip technology so it work to higher revs
C’est la vie
Rotor
dapper wrote:I use this one as do many others. You may find it cheaper but this is the first one that popped up on e bay. You need a battery to use it. Simple but effective and accurate.
Great seems very reasonable , this might be a simple solution.
Rotor
Muppet wrote:try t get one with skip technology so it work to higher revs
Do you have any more info. or details regarding this, just hate buying things twice, done that enough with scooter parts! :roll:
Muppet
High-tech internal circuitry-auto-ranging allows the timing light to skip every other flash for a brighter light and longer life
Cut n pasted from tinternet
C’est la vie
ricalnic
Main scooter: Lambretta GP Monza 225
+1
Rotor
Just purchased the Draper, thanks for the input guys
P.
Tractorman
Main scooter: Lambretta li150 special
They work OK, used mine again this morning.
