Sip 2 or me big box much better than Sito plus ?
Liquidcooled
Main scooter: Lambretta gp 200
Running a malossi 210 on a p200e, matched cases and standard up jetted carb, with old PM pipe, want to Go back to a standard look and just found sito plus in shed but was thinking of getting a SIP 2 or a mb big box, but the question is , is it worth it? If the sito plus is nearly as good I will stick with it.
Also found 30 mil dellorto, same question is it worth fitting? scooter has been mine for 30 years and is a mk 1 P 200e which is used only now and again.
Cheers
Dave
East London
hobospeed
If I were in your position I would put the SITO on for now and wait until BGM brings out a 200 version of their new Big Box that is geared towards non-touring set ups (more revs). They've just announced the small block version so a 200 shouldn't be far behind:
http://blog.scooter-center.com/vespa-au ... box-sport/
ipman
the sito plus is a copy of a standard vespa exhaust. if you look at the downpipes on all three you will see the difference
goldeneye
the sito plus is a copy of the T5 exhaust (although an original T5 pipe sounds better, and goes better imo) and I quite prefer them for a touring set up (rally scoot if ya like) I ran a SIP road on me old malossi 221, and on a HB200, and it went alrite, about the same as the Sito to be honest. I took the SIP road off, gaz powell on here lent it off me, so I fitted a simonini I had kicking about the shed, thrashed it to blackpool pre-season, and it pissed all over the SIP road! so... :lol:
storkfoot
ipman wrote:the sito plus is a copy of a standard vespa exhaust...
I did wonder why I had to down jet my standard Rally 200 from a 118 to 117 when I put the Sito on :oops:
Liquidcooled
Just ordered new BGM pro sport big box but they are waiting for new stock !, very good exchange rate at the moment
Yanker
It was perhaps coked?
storkfoot
It was probably an unfair comparison. A proper standard Rally 200 runs a 118 main. In my case, I couldn't get the original carb to run so I replaced it with a new one. However, the atomiser was P range, not Rally.
Therefore, I suppose it's possible that it would run a slightly smaller main??
