Flywheel
ArmandTanzarian
My Rally engine (non-Femsa) has the old original Ducati flywheel that I assume has been on there since new. Even with a new stator and CDI the spark is a bit wishy-washy.
Has anyone tried the SIP lightened flywheel. Apart from (hopefully) improving the spark, at 1.7Kg, it weighs a bit less than standard too.
http://www.sip-scootershop.com/en/produ ... +_51001000
Ginch
Main scooter: Vespa 150 Super
I've had one on for a couple of years. It's fine but I can't really make a comparison as it's been so long.
Have you looked at getting your flywheel re-magnetised? If that's not the issue you've done your money but woth investigating.
ArmandTanzarian
Ginch wrote:I've had one on for a couple of years. It's fine but I can't really make a comparison as it's been so long.
Do you know anywhere in the south east that does remagnetising?
Ginch
No I don't but it's worth chasing up, these guys do it for a tenner. http://www.scootopia.co.uk/page/97/Our-Services
goldeneye
that SIP flywheel looks a bit expensive like! see if you can get a px disc leccy start flywheel, take the ring gear off, and send it to Beedspeed to lighten, the last one they did for me cost about a tenner +postage. you should be able to pick a flywheel up cheap enough.
GLscoot
Main scooter: Vespa GS150
It may be worth buying one of the vintage motorcycle magazines, as there should be someone close by who will do it. Was there not an article in Scootering a few years back on this subject.
http://www.afrayspeed.co.uk/index.php?p ... buteID=ELE
Ginch
Jxmiddle
Main scooter: GP250 69 targa twin
For the remagnetising it's worth called Slip stream (motorcycle tuners) in Sevenoaks. I don't think they will do it but they would likely know someone who does, they seem to have a wide circle of expert services they know of.
John
