brass exhaust nuts
lambro
sunrisemac wrote:I decided to put mine on the inlet manifold studs instead................
Trouble with doing that is that the nyloc on the inlet nuts melts when fitted to the exhaust.
On the plus side, if you put nylocs on the exhaust studs, you can only thread them om on the one way :D
Timbo
.....put the rounded end on the stud first......that should sort it...
sunrisemac
Main scooter: Lambretta GP150
I'm gonna put 'K' nuts on in that case with a bit of lockwire, drill them for split pins and belt the ends over once fitted , that should do it ;)
slangen
Main scooter: TV200
That's it I'm putting wing nuts on.Image
slangen wrote:That's it I'm putting wing nuts on.Image
Ah but which way up are you going to fit them :lol:
slangen
Main scooter: TV200
Wings first, it will lock them up good.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 10 guests
