t5 d.side oil seal
soulboy
is the p2 seal the same size as ive put a new one in and its tight on the crank I/e the crank is now quit stiff
gaz_powell
both crank seals are the same on px and T5
did you put a bit of 2 stroke on the sealing surface before assembly to lube it as when it starts to pull home ? - if all fitted "dry" it may have dragged the seal lip.
pop crank out and check to be on safe side
goldeneye
have you got the flywheel on and clutch tightened up? sometimes it needs everything on to pull the crank in line. also, was it fitted flush with the casing? as the crank wont turn properly if its catching on the oilseal. I always lube the lip of the seal and the big end of the crank, flyside of the crank etc. with 2-stroke prior to fitting. as gaz says the crank seal may have turned as well.
bazman
As above what the lads have mentioned, but also some seals may catch on the drive bearing , think Diablo once mentioned this , but certainly another option to look into, was this a genuine metal or pattern rubber type?
soulboy
cheers fellas ;)
gaz_powell
ive said it before but I only use corteco seals and yamabond them in - put thin smear of silicon grease on the sealing lip to ease the crank install
Last failure I had was a kok brand when no corteco available - it lasted a year or so (Im stocked up with corteco now)
there are some s+"te seals out there - use either corteco or the genuine metal type steer clear of any of the black ones
let us know how you get on
soulboy
cheers gaz the one I used was black :(
gaz_powell
You should be okay if its ROLF
nam65
Main scooter: t5
just out of interest did you change the main bearing
at the same time..
soulboy
no mate its got all new bearings
    Users browsing this forum: Semrush [Bot] and 10 guests
