egt probe position
tea5ive
Main scooter: cometa 140
where does the probe need to go on the exhaust for an egt gauge. cheers simon
lockman69
100mm down from the piston skirt...
tea5ive
lockman69 wrote:100mm down from the piston skirt...
is that at tdc or bdc ? cheers simon
+1 but try to position it so that the probe faces the rear just to protect it a bit. Difficult to achieve though due to the position of the bend.
tea5ive
its going on a b-race, there is a fair bit of room so will be able to tuck it out of the way. so is the measurement taken from tdc or bdc ?.cheers simon
It's from the side of the piston, so TDC or BDC doesn't matter
tea5ive
rosscla wrote:It's from the side of the piston, so TDC or BDC doesn't matter
cheers for the info. still need a datum point to measure from don't I.... ? lets say exhaust port centre ?. don't want to feck it up . cheers simon
Muppet
from the piston in the open port
muppet,
C’est la vie
slangen
Main scooter: TV200
It does not have to be exactly 100mm, measure from piston to exhaust gasket face on cylinder then from exhaust gasket face on stub or exhaust, add thickness of gasket and mark the u bend. You create your own reference of the reads you get, if you get an air leak or so, you will notice a raise in temp. From your own reference when everything was fine...
tea5ive
thanks for the info, I no what I am doing now 8-) . will have a measure up and weld the stub on for the probe. will take a pic or two of the progress. cheers simon
    Users browsing this forum: No registered users and 31 guests
