adding battery.. no tray, no tool box..?
Knowledge
Donnie wrote:If using varitronic and battery remember that the battery is only ever getting a trickle charge. I had similar up to about a year ago using a standard vespa battery.
While some of the already mentioned batteries may do what you want the linked ones are 7Ah and 4.5Ah only, standard Vespa PX battery is 9! ..........
PS, I now run a wassell 12v dc setup with the vespa battery which happily copes with the headlight as well as the spotlight.
Donnie,
The circumstances you describe seem more attributable to the Varitronic stator than the battery. First, the Varitronic has poor power output for lighting, so it struggles to charge a battery AND run the lights. In fact, many struggle to run the lights, and would therefore drain the battery as well.
Secondly, the 9Ah battery on the Vespa has to be big because it is needed to start the engine. Few Lambrettas have electric start, so a big battery is not required (hence my previous post).
Finally, the Wassell DC set-up has solved your problem because it has a decent power output: the battery has little to do with the performance of the lighting circuit but remains a useful reservoir of power and a great stabilising element of the power circuit.
Martin
joey
..thanks for good advice so far...the battery will be used to stablize power..not to really power anything.. sip speedo/mod charger/change light/parking lights..
mounting is still a problem.. 13ltr tank.. under panel tool box will hold oil and tools..?
joeswoonara
Main scooter: jet ts1
yes it will, battery, oil and odds and sods , well that` s what i get in mine :D
Donnie
Burnside wrote:I've got a burglar alarm battery fitted on my S2, it sits between the rear mudguard and frame loop
What's it powering?
Donnie.
Donnie
Aren't the lighting and charging circuits seperate though I thought? And my varitronic lighting was fine until the coils themselves got heat damaged which can happen on any of the electronics to be fair.
Just looking up the specs of it it's a 90watt output no different than the indian ones, possibly a little more in fact as I think most sil ones are 80?
my main points though are (a) unless you go wassell dc you are trickle charging a battery, the more Ah you have the greater reserve you have to run electricals directly off battery, not a problem if its only rear brake and horn due to such intermittent use, but add a headlight and power will drain from the battery faster than it can be charged.
(b) I can see why many use the dry cell / burglar alarm batterys idea, but I still don't know of anyone that's using that system and powering a headlight on top of the horn / battery.
Donnie.
Monty
This is my MBM one
Made by Monty
It's a 4.2amp alarm battery. Get to Maplins to get an idea of sizes then buy of eBay at half the price. They can go any place you have room but beware fitting in a tool box In case you short out the terminals dropping something on top, guy at the club needed a re spray after a similar incident
steve chapman
hi matey speek to warren at shawfire , he has had some small battery boxs made
think it might be just what your looking for , his number is 07702037069 regards Steve
Burnside
Main scooter: Lambretta TV200
What's it powering?
It was for my DC conversion, only powering lights, horn and indicators
    Users browsing this forum: Amazon [Bot], Google [Bot] and 9 guests
