Spanish Jet regulator bracket?!?
purple_pill67
Main scooter: Jet200
Does anyone do a bracket for a regulator/cdi/wassell for a Jet 200?
Seems to only have the 2 holes on the flywheel side and not be the same as an Italian fixing.
Ideally wanting to tidy my electrics up and fit an under panel carrier for oil but wont be able to unless i can move the cdi/wassell out the way.
Monty
Plenty of flat sides and bottom to your proposed box that can be used to bolt stuff onto
theageofindustry
Main scooter: 74 Vijai Super
You could drill the rear support for a standard Italian cdi mount.
That's the easiest solution and what I did on mine.
purple_pill67
Ok, i havent got an oil box yet til i know what i can do with the bits.
Didnt really want to drill the frame
