Quattrini Build....
just had this fired up and she is spinning up to 10,000 revs ...according to your rev counter !
all ready now for a dyno to set carb up,and to sort out the best plot for your new fancy yellow CDI thingy :)
cartmel808
Have you managed to translate the instructions for that HHP4 cdi then Sean?... lol
cartmel808 wrote:Have you managed to translate the instructions for that HHP4 cdi then Sean?... lol
Yes, he used his translator machine.......me ;)
cartmel808
drunkmunkey6969 wrote:Yes, he used his translator machine.......me ;)
Vorsprung durch Techink! :lol:
ducksta
sean/dan could you prep my casings ready for a quattrini build welding/porting/powder coat etc without me purchasing the kit crank etc first, i need to build slowly due to funds?
GLscoot
Main scooter: Vespa GS150
Its a quality scooter Graham has built and I am also very interested on the outcome of the dyno, as my next project is either going to be the Quattrini or the PInasco.
http://www.ebay.co.uk/itm/261162067977? ... EBIDX%3AIT
cartmel808
That Pinasco kit looks good Gary... I've not seen these before - it looks to be a similar design to the m1xl, with direct intake - only @ a lot better price than the Quattrini.
Juan
The Pinasco is a rehash of their old twin induction kit which used the standard downdraught and a side draught to the barrel feed. Rose tinted glasses say they were great fun but the reality is they were a pain in the arse and the only really good thing about them was the induction roar.
Get one if you like but you'll spend considerable cash on an underwhelming kit. The Quattrini , Parmakit TSV or even a Malossi 166 will p155 all over it every day of the week. Fair enough, the Parma or Malossi is no use on a piston ported block but I'd just save a bit more for the Quattrini.
ducksta wrote:sean/dan could you prep my casings ready for a quattrini build welding/porting/powder coat etc without me purchasing the kit crank etc first, i need to build slowly due to funds?
yes matey,just pop it in sometime ,all I would require at this stage is a base gasket :)
ducksta
cheers will strip casings over xmas then drop in
