festoon bulbs
ForemanBob wrote:I modified to take LED bulbs....
Where's the "like" button? 8-)
gaz_powell
I wired mine up middle rear light and outer brake
onefortheroad
Main scooter: Li125 series 2
I've just put some of them festoon led's in. Got an led speedo bulb as well!
onefortheroad
Yeah I think it has to be middle to illuminate the number plate. I'd have thought the MOT tester would have noticed it! Twice!
Monty
I would recommend glueing the festoons in. I use a hot melt glue gun to stop them turning round in use. Not such a big problem with the large festoons shown but the smaller ones can end up facing backwards. Not a problem with a normal lamp.
onefortheroad
So I fitted the LED speedo bulb and although there's a bit of a white spot I'd say it lights up the face just as well as the normal one and certainly good enough for nighttime riding.
Waiting for the big festoon bulb to come and I'll try that too.
https://vimeo.com/114470360
ForemanBob
Main scooter: GP RT230
Monty wrote:I would recommend glueing the festoons in. I use a hot melt glue gun to stop them turning round in use. Not such a big problem with the large festoons shown but the smaller ones can end up facing backwards. Not a problem with a normal lamp.
I tiewrap them in place..... ;)
onefortheroad
Well I changed the festoon bulb in the headset for an LED one and it seems to be working well and good enough for a side light. (The festoon is the second whiter light on the video.
Glue gunned it in just to be certain
https://vimeo.com/115261870
