crankshafts
joespeed
i have looked back under other threads but cant find this, i have several cranks with duff big ends,is there a supplier out there that can supply a good quality offset b/e pin and yam .rod to suit the indian webs? i was hoping to get a bit of extra stroke and a new good quality rod at the same time use up some fair crank bits!
regards
joe
AUSSIE
readspeed do offset big end pins. They are quite dear because alot of engineering work to make them! I believe the offset is 1mm so it increases stroke by 2mm. Yam RD350 and RD400 rods will fit normal 16mm gugeon pins. the 350 is 110mm and 400 is 116mm
taffspeed do them as well . ;)
joespeed
thanks for the reply s,will try them tomorrow,
regards
joe
AUSSIE wrote:... 400 is 116mm
115mm to be pedantic :geek:
J1MS
Thats what I thought, but I didnt want to appear pedantic... :)
:lol:
AUSSIE
thank you guys for putting me right :oops: , Its good to get the correct infomation :D
