Race Rapido 225
e_9111
Main scooter: Lambretta 225 Rapido
hello everyone, I can put a red-valve on me 225RaceRapido?
without opening holes in the piston ?
this is : http://www.lambretta-teile.de/Reed-valv ... -Lambretta
I have one valve put on me engine,,,and I have problems for runing over 50 km/h,now me new-engine has consumed 4 gas deposits. can any friend help me ? Thanks
== Enrique ==
RapidoRace 225
You MUST cut holes in the piston (or buy a TS1 piston) AND re-work the inlet port in order to get back some of the losses caused by the reed valve at higher revs.
e_9111 wrote: without opening holes in the piston?
ahh ...you did not mention that ;)
e_9111
3 months I have been thinking and thinking, why not give the desired power
Carburator???, filter??? , to complete the engine running ???
and this week I I think on this Red-Valve , for what no work well ???
the engine is a bull on machine stop,,,, is Ben Johnson,,,Ufff uffff Image, the wheel to up when the loosen clutch
but when I start runing on the road
can not over 55 km/h :o :o :o :o :o
I am sorry to lose this power, if extract the Red-Valve . I think if re-couples a piston Ts1 the consumption can shot-up
¿Is this really???? and other question,,, if I change the sheets for others on less mm of thickness,,,¿that? I can solve a little
the "Problem" ??? Regards
http://www.saigonscootercentre.com/imag ... o-7028.jpg
on 41 diameter pipe for this exausht , is new model
== Enrique ==
RapidoRace 225
arthur
to be honest not got a clue what your translated post is about :bigsm: but i have a lth race rapido 225 reed valve ,i have had boost ports added and holes matched in the piston it's taken me ages to get this set up right and if i had a choice again i go straight for the ts1 or rb ...but now it is set up well it goes like a good un...cheers art
tha83
Main scooter: SX 2something
I just did up a Race Rapido 218. 200 Race barrel stroked, Broadhurst piston cut up, boost ports, transfers widened, exhaust raised, AF light fly, 5 plate clutch, Taffspeed pipe and get this......a 30 mm Lectron carb. Goes like poop off a shovel and simple a F' all to jet. Love it!
e_9111
arthur thanks for retry helper my , is ard for me,,,,thanks for alls.
I wish could use sheets, I will make some checks
and like see if changing the sheets for less thickness mm
this engine can give good power,,,,are now placed the fiberglass
I have also on carbono , I appreciate any idea
Regards
== Enrique ==
RapidoRace 225
arthur
couldn't really understand yer again but i'm running a 30mm dellorto with a 145 main jet and a av268 atomisor oh and a nk exhaust...
e_9111
Hi guys, I need any information about this damper Lambretta
http://imageprocessor.websimages.com/wi ... C01857.JPG
bought http://www.lambrettaupgrades.co.uk/
I'm living in Germany to day ,,,, need the approval code "e" xxx / xxxx given by the manufacturer
The inspector TÜV crazy about this code. as I can get?
Thanks
== Enrique ==
RapidoRace 225
Cereal GY
Main scooter: GP200
Tried contacting Lambretta Upgrades directly? Chiggy is very helpful whenever possible!
