TSR Exhaust Vs ADS3 and the missing tailcan bracket debate
DMC
Does the 'short' bracket need to be bent at 90 degrees? with the round hole fitting to the lower rear damper mount? Only way I can see it fitting.
MAB
Regarding the mounting bracket they are the same that come with the Bullet and Hornet ect ,I have had 3 in totally some pre/bent from maker and one I had bent myself and all fairly useless to be honest .
slangen
Main scooter: TV200
Donnie
Hmmm that does seem to me like an afterthought :-/
Donnie.
slangen wrote:ImageImageImage
You could easily make a 3 point side case bracket
slangen
Main scooter: TV200
It's not my side case, this is a Bullet or Voyager from Pipe Design. I posted the pictures long ago when someone asked how to use the bracket.
gaz_powell
the TSR looks different to the Pipedesign Voyager
http://www.lambretta-teile.de/Exhaust-P ... X-TV-GP-dl
    Users browsing this forum: No registered users and 67 guests
