OLD MB PIPE
yian-ts1
I have an old style steel type detour but the manifold section has got a hole in it, metal so thin now can't weld. Any ideas ? Could i get a manifold made, best pipe i've used seem better than the newer stainless ones??
Any advice??
Diablo
They are miles better. Give Broady a ring he may be able to help you out.
TS1-200
I had a similar problem with an old MB3 pipe, harry Barlow repaired it for me, even improved the ground clearance issue I had with it.
Keep on keepin on
if you want to post it to me i could get it sorted for you
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 65 guests
