Hi,i may be putting my PHBL25 on my standard 200 with AF clubman.
Im thinking of the following spec:-
D29 (cant remember position?)
268 Atom
48 Pilot
95-100 Main
Ive never used one of these on a Bretta before,anyone running similar?
S
PHBL25 on a std Lam 200
Adam_Winstone
- Main scooter: Lambretta GP
Open mouthed, through Italian filter or though Jet filter?
Adam_Winstone
^... I thought you might say that!
Nope, the only PHBL that I have is Blakey's old solid mount 24mm and I had an early 23mm standard manifold machined down to take it. I don't think that I've ever had a rubber mount carb so small!
paddyfitz
Common setup. I've done bunches with that carb.
I like that needle in tandem with a 266 atomizer. Typically wants a larger idle than that for a 200...
Maybe spring for the larger aperture float seat while you're at it. 300 is the one I like.
