Lammy chaincase gaskets
Ihateyoubutler
What are the best series 123 chaincase gaskets people are using? Don't know about the cork ones, but the green (mec?) ones used in the past seem very good. The grey (graphite?) ones don't seem to seal very well.
Thanks.
bolzenanker
Main scooter: Spanish S2 Li150 1963
I use the 1mm and 2mm thick ones from Camlam. They last for ages even with my frequent forays inside. Did try the cork ones which are nice but didn't stand up for too many chaincase removals.
jason frost
I always spray some white grease on them, stops them sticking when you open it up again and they can be used again.
I've used cheap eBay ones most and never had any leakage problems but I do usually end up tearing them when removing the side case if it has been on a while.
