Sh filter
sydduckett
Anyone know of a filter that can be fitted to a SH20. don't want to use box but still want a filter?
Ta
Sef
What box? I'm not quite sure what that means. Are you after an inline filter?
AUSSIE
By box I guess you mean the standard steel air filter box.
I would think the easiest way to fixing a filter is for you to keep the rubber elbow and fix a k&n style filter to the end of the rubber elbow. you just need a solid ring to push inside the elbow and a k&n style filter to fit over the outside the elbow.
sydduckett
AUSSIE wrote:By box I guess you mean the standard steel air filter box.
that's not a bad idea, it's a rat so will suit the homemade look :D
Ta
Ah, an air filter. I knew that really. :oops:
Mr Duckett I have a 22mm breath sweet filter somewhere that I've never used, for just such a thing. Any good to you?
sydduckett
Doom Patrol wrote:Ah, an air filter. I knew that really. :oops:
Yes I would be interested sir
I'll see if I can dig it out for you.
    Users browsing this forum: No registered users and 23 guests
