Centre badge
Blackhawk
Main scooter: T5 Classic
Another quick question. What's the technique for fitting the centre badge on the horn cover on a 150s. There must be a technique but I don't have it :D
10 inch Terror
Xbox live gamer tag: No.
You have the badge holder I take it? It bolts to the frame through the horncasting and the badge then clips into that.
10 inch Terror
One of these bad boys.
Blackhawk
The horn casing has 4 slits and the badge has 4 tabs that go into the slits. I'm having trouble with the technique of marrying the two up without damaging the badge.
10 inch Terror
Forget everything I said. I thought you meant a Lambretta 150! Sorry it's my age... :D
Blackhawk
I managed to get it in. I had to put a curve in the tabs as they were snagging the frame inside. Anyhoo, job done.
barnsleybilly
Main scooter: Li200
Do you mean an Ulma Golfball embellisher on a series 2?
