Also should the tank be matched or black?
Cheers,
Stu
PIA_210 by dent.graham, on FlickrAgree with cartmel. You should be able to remove the tool box lock with out any trouble, if your steering look is in the same place as a GS150 you should be able to remove the large threaded part and push it into the cable tunnel and then fish it out with a piece of wire, I think its easier to remove from the bottom.Blackhawk wrote:Brilliant, many thanks Cartmel. Now I don't have keys so should I send it for spraying with the old locks in (hoping I can get keys made) or drill them out?
Stu
