Ok not to sure if anyone is interested ? so ill carry on regardless
So this was the first fit ,and just trying to decide where to cut. This is/was a mk3 57 model and has a tool box in the back, and i decided i wanted to try and keep it if possible . It would of been a lot easier to cut it out ! but, hey, who want easy
so out with the grinder again.
and its getting nearer .
I had to make up a shroud to go around the shocker and seal the tool bxo up, as you can see , i initially cut a little to much out to start with
but that can be welded back in
The shocker top mount is a problem area , as really the loop needs to go lower , but would mean cutting the loop around the shocker , but thats no good, so a few hours of trial and error, and head scratching to decide on the best position .
