SIP Lambretta Digital Speedo
Andy W
Main scooter: GP 186 Imola
I have done the same as Minority and I'm sure I used a Oil Level plug as fitted to the chaincase cover, hope that helps.
Nerdy Norm
Thanks Andy, but the oil level plug is a bolt, right? I think Minority is talking about a spacer nut, or am I missing something?
Minority
Main scooter: Li230 S3
Nerdy Norm wrote:Thanks Andy, but the oil level plug is a bolt, right? I think Minority is talking about a spacer nut, or am I missing something?
Yes it was just an ordinary nut that happened to fit over the axle and was about the right thickness. Unfortunately I have no idea what size it was, I just found one in my box of nuts and bolts that fitted.
Nerdy Norm
Thanks - and there was me thinking that I'd need a special "MBD CNC-machined stainless speedo drive spacing system" ;)
Andy W
Ahh I see what he's done now, can't see pics on works computer. I thought he had removed the speedo drive and blanked off the hole the brass piece and worm drive fit into. Sorry about that.
Nerdy Norm
No problem Andy, always nice to have options.
victor
Main scooter: Tv175 but currently a SS210 :)
So, if I swap to mph it also displays F... Any way to keep C as temperature?
Or do I have to manually reprogram the kmh speed to show mph if I want Celsius?
Minority
victor wrote:So, if I swap to mph it also displays F... Any way to keep C as temperature?
You have two choices as standard, MPH/F or KPH/C.
If you want MPH/C you will have to mess around with the tyre circumference to fudge it as you suggested.
In theory if you set to KPH/C and divide your tyre circumference by 1.6 (if that's within the allowed range) you should be about right.
victor
That was my thinking to - thanks for confirming!
kalifornia
Main scooter: Lambretta Li150 Special
I've not been through all of the responses on this thread but I was having problems with my SIP speedo freezing and not starting up properly etc.
It appears that you must run a resistor type spark plug if you are running a battery-less A/C system to make them work correctly. I switched from a B8ES to a BR8ES and it works perfectly now.
Hope this helps.
