gearing
skinhead63
Main scooter: px 225 ish
hi peps im building a 210 with 60mm crank pwk 28 mm carb,reed induction with rd 350 reed valve would like to know what gearing to use other than T5 4th which is going in also using a jl3 r/h pipe.
LI150
Main scooter: Series 2 LI150
Same spec as mine and I'm using 22/68
1469leach
Main scooter: jet200/rapido 225
I've got the same set up and I'm running 23/64 with 36 t 3rd and 4th,gives 4.77 final drive and pulls fine.mines a malossi btw.
cheers Jeff
